Author Topic: Active balancer.... anyone want to speculate how this work?  (Read 672 times)
Offline paulcaTopic starter
« on: August 19, 2019, 03:35:16 pm »
Offline mikerj
Re: Active balancer.... anyone want to speculate how this work?
« Reply #1 on: August 19, 2019, 04:12:17 pm »
Looks like a buck/boost balancer.  AFAIK these simple non-coupled inductor designs can only transfer charge between adjacent cells, so on anything with more than two cells you can't transfer charge between the end two cells.
Offline SparkyFX
« Reply #2 on: August 19, 2019, 04:26:29 pm »
Underside of the PCB would be interesting, should there be anything.
I suspect it just makes use of an inverting boost converter, which could enable charging the lower cell and might be able to switch to non-inverting for reverse operation.
Support your local planet.
« Reply #3 on: August 19, 2019, 06:28:43 pm »
That's the thing.  It "seems" to be working on a 3 series and... bidirectionally too.
Offline mikerj
« Reply #4 on: August 19, 2019, 11:03:02 pm »
Yes it still works on a 3S, but the limitation on transferring energy between adjacent cells means it may have to transfer the energy multiple times across cells which drops efficiency but still a lot better than the simple resistor load style balancers.
Lots of info on this and other topologies if you google "buck boost cell balancer"
