Author Topic: Selective Zero Point Switching  (Read 542 times)
Offline TheDoodTopic starter
« on: September 15, 2019, 05:38:26 am »
Say you have an AC signal at 100hz. Is it possible to pick the exact oscillation that you zero point switch? If there's 100 oscillations per second, could you switch at the zero point of every 1st & 23rd osscillation, for example? Is there such a device or cct that is commonly used that accomplishes this?
Offline gigabyte091
  • Country: hr
Re: Selective Zero Point Switching
« Reply #1 on: September 15, 2019, 06:21:01 am »
You could use zero cross detection circuit, and then feed that signal in arduino where you can count pulses and switch output when you want (eg. 1 and 23rd zero cross of the AC signal)
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: September 15, 2019, 06:36:36 am »
You may be missing some terminology:
Oscillation: an alternating phenomenon, usually periodic.
Cycle: a full... cycle, of an oscillation.
Also, what would the 1st and 23rd cycles be referenced to?  If the oscillation is steady state, it doesn't really have a beginning or an end.  (An ideal sine wave, for all times t < 0, is identical to all times t > 0, give or take a simple symmetry.)  Would the count repeat immediately, so the 24th cycle from one count is the first cycle of the next count, and so on?  Or should there be some dwell in there also, in which case how much?
But in any case, yes, that's a thing: a cycle-skipping controller, is typically used for AC loads, that have high power factor, and large time constants, so that the skipped cycles average to a smooth output.  In short: heaters, thermostats, that sort of thing, are a prime application.
The pattern of cycle-skipping may resemble PWM, or a sigma-delta converter, or anything else that works.
PWM would run, for a duty cycle 0 <= D <= 1: on for N*D cycles, off for N*(1-D) cycles, for a total (repeating) period of N cycles, or a frequency of F_mains / N.
Sigma-delta is something of an approximation method, which can give lower ripple than PWM.  A running average is calculated by the controller, and the output is turned on or off depending on whether that average is above or below the setpoint.
The simplest, commonest circuit you could make, that accomplishes this, would be a simple hysteretic controller (i.e., a sensor's output is compared to the desired setting, and this turns the output on or off directly), paired with a zero-crossing switch.  Downside, this gives much slower cycles, and quite a lot more ripple (fluctuation in sensed value), than a PWM or SD control would.  (Most home thermostats do operate this way, in part because the furnace or A/C should not be switched on and off too quickly.)
Seven Transistor Labs, LLC
The following users thanked this post: TheDood
