Hello everybody.
Right. I want to build a Bench PSU using a laptop charger and connect a couple of LM317's to adjust current and voltage.
The charger has got 19V 3.95A (from my toshiba satellite) and I want 1A at at least 12V.
Now comes the tricky part.
I'm expecting to have a voltage drop because of the LM317's so the max. voltage will probably be 12 to 15V.
It's the amps that mess me up.
Acording to Ohm's law I would need a 19R 19W Load Resistor to get 1A which is my target. But the output of the transformer is 75.1W.
Now, how much power and resistance do I need to get the 1A
I've laded a schematic to give you a better idea. the load resistor is on the left.
Thanks
