Author Topic: Sense resistor  (Read 4200 times)
Offline Hex173tTopic starter
Sense resistor
« on: February 14, 2012, 11:38:24 pm »
I need a low ohm sense resistor for a battery charger IC (Max713) for charge current feedback.  It works out that I need .694 ohm.  I don't have this value in a real resistor, I was thinking of using a length of aluminum 24 awg wire instead.  I can't think of why this wouldn't work.  Is there a good reason not to do this, like it would cause some technical issue?  Please keep in mind this is on a bread board and temporary.
Thanks in advance
Bill
Offline BravoV
  • +++ ATH1
Re: Sense resistor
« Reply #1 on: February 14, 2012, 11:56:11 pm »
Get three resistors which are one 1.2 Ohm and two 3.3 Ohm, put them in parallel and you will get a resistance approx. 0.694 Ohm which is quite close to what you need.
Offline grenert
Re: Sense resistor
« Reply #2 on: February 15, 2012, 01:39:48 am »
At only 0.02567 ohms per foot, you'd need a lot of wire to reach .694 ohms.  A lot more than you could deal with on a breadboard (>20 feet).
Parallel resistors is a great solution.
Offline Rufus
Re: Sense resistor
« Reply #3 on: February 15, 2012, 03:13:08 am »
0R68 is an E6 value and only 2% out.
Offline ejeffrey
Re: Sense resistor
« Reply #4 on: February 15, 2012, 10:20:45 am »
If you have to use a wire a resistive wire like nichrome is better.  It will be shorter and have a lower tempco than aluminum wire.
Re: Sense resistor
« Reply #5 on: February 15, 2012, 05:39:24 pm »
Thanks for all the ideas.    I didn't mention but I only have (5) 12 ohm and (10) 10 ohm and will give .706, acceptable I think.  And I did a quick test of 6 feet of wire and it works out to be .176 ohm, so I need 24 feet of wire which I don't have. Bottom line, whether I go with with nichrome or fixed resistor combos, I alot of wire, alot of resistors or need to do some shopping.
I do appreciate the replys, I didn't know about nichrome.
Bill
Offline robrenz
  • Real Machinist, Wannabe EE
Re: Sense resistor
« Reply #6 on: February 15, 2012, 05:44:41 pm »
I have purchased nichrome from here several times with good success.  they have assortments also.
http://stores.ebay.com/Wires-Store/_i.html?_fsub=657165
