Author Topic: Simple Speaker Selector  (Read 470 times)
Offline DarlingtonTopic starter
« on: January 12, 2025, 06:42:32 pm »
Hello community,
I am trying to design a simple spekaer selector for 100V line speakers.
I will leave you part of the circuit here.
I have a serious doubt regarding any clicks or pops that might occur at the during switching to one of the 4 zones provided.
I assume that the length of the cables could affect this even more as the parasitic capacitances could increase the problem.
What are your thoughts on this? Could anyone recommend any modifications that could be made?
« Last Edit: January 12, 2025, 08:28:43 pm by KKK »
Offline m k
Re: Simple Speaker Selector
« Reply #1 on: January 24, 2025, 05:52:26 pm »
You need a snubber that disconnects later.
Maybe two relays per channel is needed.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
Offline JustMeHere
« Reply #2 on: January 24, 2025, 08:06:06 pm »
You need to account for amps that do not have a common ground.  It looks like you're only switching one speaker wire.
Also, in amps that do have a common ground, you want to keep your wires next to each other to prevent noise from cross-talk and ground loops.
