Author Topic: sensors watertight  (Read 1081 times)
Offline salviadorTopic starter
    • https://www.youtube.com/user/mancio92M
sensors watertight
« on: August 18, 2015, 08:44:14 am »
Hi, I have a waterproof box "1555BGY", I want to insert the sensors such as temperature , humidity and also pressure.
I want to measure atmospheric conditions outside.
The waterproof box affects the poor measure sensors?
Offline jpenn
Re: sensors watertight
« Reply #1 on: August 18, 2015, 03:04:39 pm »
You can't do that! Humidity sensors need to be exposed to the air as do the barometric sensors. The best bet for this situation is to mount it out of the direct sun an put a splash cover over the unit. Make sure its open on the bottom to drain excess moisture.
