Thankyou for the feedback.
Apologies for the slack capitalization
I am implementing a VREF signal that varies based on a control/status pin (TPS2121RUXR). The VREF signal i am generating is via a voltage divider, which is modified by the NMOS when the status pin goes high/low.
Currently, the lower voltage obtained by turning on the NMOS happens tooo quickly before the system is ready for it, so i want to delay it.
I have fired up lLTSpice (for the first time) and took a couple of hours figuring out how to plug everything in and come to the conclusion that the diode solution does not affect the delay in the order of magnitude i ultimately require.
So i have added a resistor on the gate and a capacitor from the gate to the source and this is looking like what i want to achieve.
It slows the turn on time a bit, but that doesn't effect what i am trying to do, and its seems to slow the turn off considerably which IS what i want.
Questions:- Is this a recommended/acceptable way to achieve a delay in my VREF signal changing? (GREEN)
- Is there a better way to simulate an IC status pin other than my voltage source which goes from 0-5V and back to 0V in LTSpice.
note: absolutely zero thought has gone into the selection of R4 and C1 values apart from seeing if it changes the waveform.
GREEN = VREF (top of R3)
RED = STATUS PIN
BLUE = Voltage at GATE
Am i on the right track, or have i derailed completely. Re-adding the caveat that i know nothing, but know more that i did a few hours ago
