Author Topic: serial to Ethernet IC  (Read 1646 times)
Offline alamwteTopic starter
  • Country: af
« on: April 13, 2021, 08:24:34 am »
I am looking for an IC that convert serial to Ethernet , and be under the web.
But I can not find anything.
Would you introduce me an IC ?
Online kripton2035
Re: serial to Ethernet IC
« Reply #1 on: April 13, 2021, 08:55:18 am »
I have no IC to show you, but a module that just do that. it can do a lot more as it has an esp32 inside.
https://www.seeedstudio.com/Ethernet-module-based-on-ESP32-series-WT32-ETH01-p-4736.html
The following users thanked this post: alamwte
Offline Benta
« Reply #2 on: April 13, 2021, 03:50:32 pm »
Never heard of such a thing.
General solution would be a microcontroller with Ethernet controller and serial port(s). Plenty of those around, but you'll need one with well-supported TCP/IP stack (if you're lucky, it might be free).
Offline fordem
  • Country: gy
« Reply #3 on: April 13, 2021, 05:10:38 pm »
Google ethernet terminal server
Offline MadScientist
« Reply #4 on: April 13, 2021, 11:30:37 pm »
I think wiznet do one.
EE's: We use silicon to make things  smaller!
Online JustMeHere
« Reply #5 on: April 14, 2021, 02:43:18 am »
https://www.microchip.com/wwwproducts/en/ENC28J60
I bought some of these off of ebay already on a breakout board.  I've never used them though.
  • Country: af
« Reply #6 on: April 14, 2021, 05:16:42 am »
Thank you all to guide me  :-+
Offline ebclr
« Reply #7 on: April 14, 2021, 11:11:31 am »
Offline RoadRunner
« Reply #8 on: April 14, 2021, 01:41:58 pm »
Lantronix has few products which are in size of Ethernet jack. Expensive ~70USD, but nice black box solution. Lantronix also has driver for windows to make it look like a serial port.
There will be no off the self single chip solution. you can make one in few hours. Take any Ethernet dev board may be microchip or even a Raspberry, have socket open on Ethernet and use a serial port to push data in and out of socket. Make it appear like a serial port in windows would need a driver. Doing custom driver in Windows is hard.
Offline Pack34
« Reply #9 on: April 14, 2021, 02:49:50 pm »
I used to use the ENC28J60 a lot with some small 8bit PICs. Seemed to work great but I wasn't sending a lot of data back and forth. Just about a dozen uint16s every 100ms.
