It's the same way you demagnetize anything - An AC current through a solenoid coil with fade out. I use a cassette tape head demagnetizer but those are from the Jurassic era, on each open jaw end.
You have to fade out the AC magnetic field to get the residual flux as low as possible. Slowly moving the solenoid further away.
You could put a few wire loops in and measure AC current in a heater or something.
It's only if you notice the jaws are magnetized (paper clip sticking lightly) and the readings seem low or sticky.
Other people might have better methods.
