Author Topic: Series / parallel switching two power supplies?  (Read 1474 times)
Offline Chris WilsonTopic starter
  • Race car engineer, dog lover, hoarder.
« on: October 27, 2016, 02:50:59 pm »
I have two HP computer 50V server power supplies switched as series or parallel using the switch arrangement similar to the attached image. I get 100V or 50V (at a LOT of Amps.... ;) Given I have a 3 way two pole rotary switch can I arrange it so in the third position I get 50V but from just one of the two supplies? Should be easy to work out, but I am having a "senior" moment here <LOL>  Thanks.
Best regards,
                 Chris Wilson.
Offline electr_peter
  • Country: lt
Re: Series / parallel switching two power supplies?
« Reply #1 on: October 27, 2016, 06:50:38 pm »
I guess you can. Just add small modification to switching arrangement and use either parallel or series or single PSU.
« Reply #2 on: October 28, 2016, 05:29:06 pm »
Thanks Peter, feeling stupid, but I just got a mental block about it :)
Best regards,
                 Chris Wilson.
Offline Paul Moir
« Reply #3 on: October 28, 2016, 06:00:42 pm »
Make sure that switch is break-before-make!
« Reply #4 on: October 28, 2016, 07:17:17 pm »
Thanks for the warning, it is, but I won't be doing any hot switching, cheers Paul.
Best regards,
                 Chris Wilson.
