Author Topic: Easiest solution for a 24VAC power supply  (Read 18225 times)
Offline lewis
  • Nullius in verba
Re: Easiest solution for a 24VAC power supply
« Reply #25 on: April 28, 2014, 09:06:29 am »
But your full bridge gives 12 volts after rectification right?
Nope! It will give about 32V DC after rectification. Why did you think it was 12V?
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
Offline miguelvp
« Reply #26 on: April 28, 2014, 02:55:43 pm »
Because I'm an idiot and did my math with 120V pp instead of 300Vpp  |O
