Author Topic: PIR circuit with a timer  (Read 4979 times)
Offline mrdrakoTopic starter
« on: October 02, 2013, 01:47:01 am »
Hi, first post here ever, please be kind.  :)
I have a project in mind, and I'm not sure how to go about designing the circuit. I 'think' it should be fairly simple, but it is currently beyond my abilities. Here's a short description.
I have a Halloween fog machine, from the manufacturer it requires you to step on a pedal to make the machine emit fog. I'd like to automate this process, with a PIR, so that when the kiddies come near my front door, it fogs up the porch as they approach. However, I don't want it triggering the whole time they are on the porch, so it really needs some kind of a timeout feature.
I had thought to make a circuit similar to the one here: http://www.electroschematics.com/6039/security-light-switch-with-pir-sensor/?ModPagespeed=noscript but using a Parallax PIR (#555-28027-RT).  The documentation page for the sensor is here: http://www.parallax.com/downloads/pir-sensor-rev-b-product-documentation
The original circuit as designed has a PIR that has a selectable delay built into it, but my Parallax one does not. I thought to use the relay in the circuit to splice into the pedal wiring and trigger the fog. A LED showing a triggered state is not necessary, but may be good to use during the testing phase. I could always remove it later.
So, I have the following questions:
1 - is this circuit still appropriate even, given the part differences?
2 - Can anyone help me design the desired circuit? I am assuming that I need to potentially integrate a 555 timer into the circuit somehow, but I could be way off base here.
3 - How 'programmable' can I make the timer delay setting? I assume I could probably do exactly what I'm searching for with an arduino, but I'd rather not dedicate a unit to a once a year purpose, I'd rather have a dedicated circuit board.
Thanks for the help, in advance.
Offline David_AVD
Re: PIR circuit with a timer
« Reply #1 on: October 02, 2013, 02:04:51 am »
What you want is sometimes called a monostable or one-shot timer.
Here's an example.
http://www.dummies.com/how-to/content/electronics-components-555-timer-chip-in-monostabl.html
You can also buy little modules on eBay that do the same thing.
Offline Stonent
« Reply #2 on: October 02, 2013, 03:38:17 am »
I was thinking along the lines of those motion sensor lights that people put around their houses that turn on if someone gets near it. Though I don't recall what the warm-up time is for a fog machine. I have one in storage somewhere but haven't used it in ages.
Offline Paul Price
« Reply #3 on: October 02, 2013, 07:16:47 pm »
PIR motion sensors to turn on lights, etc. that feature a timed-turn off (for instance for a hall light that only stays on for a min or so.) are easily available at your local hardware store. You should be able to easily hack it to fit your needs.
Offline chibiace
« Reply #4 on: October 02, 2013, 07:54:29 pm »
the modules i got from the store for some jobs are mains voltage have 2 adjustment pots one for sensitivity and one for on time and are weather sealed, hook up to a relay and your set.
He Who Controls The Spice Controls The Universe
