Should I be switching the active and the neutral?
Here in Northern Europe, mains sockets are nonpolarized –– see schuko sockets; AKA CEE 7/3 ––, so it is an absolute must.
I very recently bought some socket adapters with a switch, because it is easier to turn the switch than disconnect devices like chargers, and my tea maker that I removed the two-hour keep-warm limit accidentally; otherwise its plate would be always hot. I have to check the switch in such things so they really do have a dual-pole switch, because many cheap Chinese devices have only a single-pole one.
I refuse to be a slave to my cellphone, so I often leave it in its charger. To prolong the battery life, I can now just switch off the charger from mains, without having to remove any cables or connectors, and only turn it on at night for charging every couple of days. I wanted to do the same to this laptop charger, but the mains socket is in an awkward place, so will have to get an extension cable with a built-in switch.
