Thanks. My ideas are beginning to take shape.
I think I will leave out rotary switches. Even though I could have both, rotary switches and banana plugs, I find they are too expensive and not worth the expense.
Also, I have found I have a box full of old style, 4 mm round pin, 19 mm centers, panel outlets so I am going to try using those. As each one has two holes I will mount them vertically so each transformer tap is connected to a pair and that way I can connect something else like a voltmeter or whatever. I just have to make sure I label everything correctly and understand what goes where.
A Schuko socket across the whole winding might be useful but they are so bulky I would rather leave it out and do external connections as needed.
It is a good idea to have a couple of base sockets where I can externally connect the incandescent lightbulbs. I think I will do that.
I do not think individual fuses on each tap is really necessary. It seems more complicated and trouble than it is worth. The main use of the lower voltages is not to get a low voltage output but rather to subtract from the isolated 220/125 V output which is too high with no load or light load. This is not a transformer to be used in a permanent installation but rather it is going to be used at the workbench and always supervised. It just seems to me that having a fuse for each tap is a bit much. I suppose I could do it... I'll think about it. As I say, this is to be used on the workbench. I think just using my common sense, like I have been doing all these years, should suffice.
Another idea that I have is that I have a box full of old VU panel instruments and I could use on on the front panel as a volt meter. this seems like a good idea. Leave two leads hanging out and connect them to whatever output taps I want to measure. Or that could be done with cheap rotary switches as they would carry very low current.
I have to think of all this in the context of what housing I will be using. This is becoming the biggest hurdle now. I would want a metal enclosure but I prefer to work with wood. I need to think about this.
