FIRST: My sincere apologies to the OP for bogarting this thread topic!
... sounds like a good fit for Mr Carlson's Patreon Course ?
I am a member of Mr. Carlson's Patreon but haven't seen "the course" you're referring to. I had high hopes (still do) that I would learn a lot from Mr. Carlson and the other members there but it has been woefully over my head so I rarely go there anymore as it seems to just be a waste of time since I don't understand most of what is said there.
Wil, I think I understand. Many of us remember the promise of Heathkit. But to be frank, all you learned from the kits was how to solder.
What follows is said without knowing your previous experience and why you chose your current path.
A good book I keep in my private library near the shower, Practical Electronics for Inventors by Scherz and Monk, provides excellent instruction on many aspects of the field as well as thoughts on setting up a lab and using instruments. This is well worth buying before you give up.
Maybe look at some of the approaches developed in response to STEM. Arduino and Rasberry PI come to mind.
These are module based and rely on some computer programming. But there is a world of tutorials.
As others have said, everything depends upon your goals (short and long term). But this is a challenging area that is very intellectual. You cannot SEE what is going on like you can with a car or woodworking. You have to measure and then deduce what those measurements mean. Just reading schematics can be more challenging than reading a topographic map.
And, no one has said it yet. But jumping in on non working kits built by an unknown person is risky. Yes, in time it can be done. But I would not recommend it as a place to jump in for the sake of safety. OTOH, the equipment from that era is bulky, sucks energy, and not as good as perfectly good comparably priced equipment on eBay that was "obsoleted" by companies as standards changed.
There are quite a few questions there I would like to address... first, why I chose my path. Almost all other questions can be answered by my answer to this question I believe so here goes... I'm at the end of my (software) career. In my career, I'm on top and understand everything there is to know, can instantly diagnose pretty much anything, can create anything from scratch, and need no one for help with anything. My aplogies for sounding vain. I do not want to sound or come across vain. I only say this to setup my own personal expectations of myself... I'm SO used to having all the answers that I expect myself to BE at that level with electronics. I know my expectations are ridiculous but it's hard to expect anything else of yourself when (in your little bubble) everything can be done in your sleep. Very long story short... I have extremely high and probably unrealistic expectations of ramping up my electronics knowledge and THAT is the primary cause of my frustration. So... frustration root cause #1... EXPECTATIONS (unrealistic).
STEM/Arduino/RasbPi: Yes, these are certainly options that are tangential to my career but I wanted to eliminate as many variables as possible while learning electronics. I wanted just the fundamentals without all of the bells and whistles. Antique radios are (I think?) fairly simple and pair well with that goal. There are no transistors of any kind (well, in my path so far), there are no ICs, there are no CPUs, GPUs... there are only resistors, capacitors, vacuum tubes, a power supply, a speaker, and an antenna. The simplicity of the entire package was my original reason for choosing this as a starter medium.
Response to working on "Kits": Acknowledged. My only thought was that they were simple, schematics were readily available, and that the kits I chose would be useful tools down the line for diagnosing issues with radio gear. So logically (in my mind) it made sense.
Will, I took a look at your history on the forum to try and get a better understanding of your history here. Back in Nov 2023 you said this about yourself -
Tim & Don,
Sorry... I have zero history with electronics and tubes so what is obvious to you/most, isn't clear to me at all... yet. I'm working on it.
That was three months ago. But you said "I have zero history with electronics and tubes. Zero history with electronics and in three months you want to restore radios and test equipment? To my mind that a very heavy lift.
I understand how you could be frustrated now. But on the other hand you are being a bit unrealistic. There is a lot to learn in this hobby and three months isn't enough time to get up to speed if you have Zero knowledge of electronics. I really think you are being a bit unrealistic with your goals in the hobby. I don't know how much "basic" electronics you can learn from restoring old electronics that are bound to have some quirky issues that may require a person with years of experience.
If I were you I'd step back and learn more of the basics. You seem to have a lot of test equipment so you'd have a good start learning some kits or basic Arduino interfacing to things such as LEDs, and sensors. You cound also go through some basic electronincs on the internet and make up the circuits yourself.
I don't know what else to tell you but I'd listen to other people here and see what they say.
You are correct sir. I touched on the arduino / raspberry pi topic a bit above (and I have considered this again and again) but let me go over that a bit again. It's, "too close to work" as I don't really want to do any more software since I'm nearing the end of a lifetime of software. I also have no interest (at this point) in anything that involves circuit boards ("PCBs"), ICs, or "chips" of any kind. My logic there is that those kits do not overlap (much) with the kinds of things I want to work on [initially]... antique radios from the 1940s through maybe the 1960s. And again, I do not want to "bring my work home with me" so if it resembles software development in any way, shape, or form... I want to avoid it. My brain is already tired at the end of each day so I want to work on something completely unrelated, and to be honest... non complicated... hence the antique radios.
I am 100% positive that every person here has an intrisic need to solve puzzles of some kind and that is why we chose the professions and hobbies we're discussing. The puzzle I've chosen was [basic] electronics. The goal was to be able to fix some simple things but I never have had any aspirations of even looking at something with a circuit board. The puzzle should be slightly more intellectually stimulating that raking the lawn but less tasking than... anything involving a chip.
I would be much further along in my projects if I hadn't expected so much from myself and not giving up when I hit some mental frustration because of it.
Ditto.
What you said about the anxiety of not feeling perfectly competent..... I fully understand. I was basically self taught in watchmaking (with access to some highly skilled people).
It is the lack of that access to highly skilled people that I miss. I have team members coming to me daily for help with issues and I'm super glad to help anyone with issues. I don't have that when I'm home alone trying to learn electronics. You might say, "Well, you have everyone here and so on..." and that would be true but it's not "real time". I cannot just ping someone on teams and instantly have the answer... and I'm used to that "instant answer" situation... and that is also frustrating that I cannot get immediate answers to what I'm doing wrong.
I'm impatient when it comes to learning things. I hated college because they would talk for an hour and then tell you to read 20 pages and they'd see you next week. I would read the 20 pages in the next 45 minutes and then I wanted to keep going. The part of waiting a week to keep going does not work for me. I want to get A done, move on to B immediately, get B done, move on to C... and so on. My mind does not like or do well with "conventional teaching strategy".
That said, I can slow down and do whatever is necessary to "groc" the fundamentals since I have no timeline... other than wanting to accomplish something meaningful sometime soon.
Thank you to everyone who has taken the time to respond. Your thoughts and guidance is truly appreciated!
- Wil
