Author Topic: Multiple i2c devices on single isolator?  (Read 928 times)
Offline mayorTopic starter
« on: May 30, 2021, 04:03:16 pm »
I'm considering building a carrier board for Atlas Scientific amplifier boards (used to read ORP, pH and temperature), similar to their board: https://atlas-scientific.com/files/Wi-Fi-Pool-kit-setup-guide.pdf. I plan on using my own long-range microcontroller board instead of the Huzzah board.
Apologies for the quality of the image, but this basically shows 3 isolated i2c boards and one non-isolated. They use https://www.analog.com/media/en/technical-documentation/data-sheets/ADM3260.pdf for isolation.
Each is along these lines:
Besides the fact that they use the enable/disable pin on the isolator to turn each of the sensors on and off, my question is: could you use a single isolator and tie the i2c bus of each sensor (they all have separate addresses) together instead of using 3 isolators?
Thanks!
