Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Sharing a UART with an FTDI chip and a bluetooth module?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Sharing a UART with an FTDI chip and a bluetooth module? (Read 2491 times)
networkingdude
Contributor
on:
September 22, 2012, 06:52:37 pm »
I'm working on a project that needs to have multiple ways to connect to the micro controller. My question is what would be the most cost effective way to achieve this?
I'll be using a FTDI rs-232 device and a bluetooth module. Can i just selectivity cut power to each or will this cause some issues?
Thanks for the advice!
Logged
8086
Super Contributor
Country:
Re: Sharing a UART with an FTDI chip and a bluetooth module?
Reply #1 on:
September 22, 2012, 07:14:44 pm »
Are you short of pins on the microcontroller? You could use soft serial for one of them if it's not too fast.
Logged
networkingdude
Contributor
Reply #2 on:
September 22, 2012, 07:52:28 pm »
There are no options to use other pins. It's a STN1170 OBD-2 IC
Logged
8086
Super Contributor
Country:
Reply #3 on:
September 22, 2012, 07:54:25 pm »
Ah. In that case use a multiplexor IC. I assume you don't need to have both in operation initally, or both listening, before deciding on one to use?
Logged
networkingdude
Contributor
Reply #4 on:
September 22, 2012, 07:57:26 pm »
Thats right only one active at a time. Could I just switch the power to the FTDI and the bluetooth module?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
