This is regarding the purpose of what is called as "shield" in connectors?
I want to understand why do we need "shield" in connectors and why is it required?
I happen to go through ethernet and saw the RJ45 connectors which has shield.
I read that the shield is just the outer metal casing of the RJ45 connector. But how it is connected to the chassis ground, I am not sure. Also, why it is required?
