Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Shielded cable that cannot be grounded
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Shielded cable that cannot be grounded (Read 3823 times)
pcblearner
Contributor
on:
April 22, 2015, 01:19:00 am »
Hello
Here is a newbie question... I want to use a cable for some signal lines (I2C to be exact) and since this cable goes between boards, I would like the cable to be shielded. Now, my understanding is that if the shield of the cable is not connected to signal ground, it can actually behave as an antenna (as EMI can induce voltages on the shield) which is bad.
So, why is it that when I look at cables like this:
http://www.digikey.com.au/product-detail/en/30-00279/T1247-30-ND/4581653
There is clearly a shield, but I cannot see any way to actually connect to the ground... I am wondering if I am missing something here...
Thanks
Logged
sparx
Contributor
Country:
Re: Shielded cable that cannot be grounded
Reply #1 on:
April 22, 2015, 01:21:45 am »
Afaik the connector jacket may make a physical connection to the shield (Such as the case with satellite coaxial cable and F connectors do), or may accept a soldered connection to connect the shield?
Logged
PeterFW
Frequent Contributor
Country:
Reply #2 on:
April 22, 2015, 01:56:44 am »
Quote from: pcblearner on April 22, 2015, 01:19:00 am
There are soooo many different ways to connect the shielding of a cable, i guess you mean the "braidet copper" part around the main conductors.
Depending on the connector the shield makes the connection though a press fit, crimp or you untangle it, put shrink wrap over it and treat it like a 4th conductor.
Here is a picture:
https://robrobinette.com/images/Audio/Canare_Star_Quad_Cable.JPG
Logged
Richard Crowley
Super Contributor
Country:
KJ7YLK
Reply #3 on:
April 22, 2015, 02:24:50 am »
The shield (whether it is braided or simply spiral-wapped) is simply "unraveled" and twisted together as its own wire. Then you connect it just as you would any of the inner wires.
Logged
pcblearner
Contributor
Reply #4 on:
April 22, 2015, 02:46:59 am »
Thanks everyone
I understand now.
Logged
KeepItSimpleStupid
Regular Contributor
Reply #5 on:
April 22, 2015, 03:10:04 am »
Unraveling, is the wrong way to do it. You actually make a hole in the shield by pushing the braid aside and then pull the center conductor through that hole unless the cable is such that it's so poorly designed it won't allow that.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
