Author Topic: Why short source and drain on a JFET transistor?  (Read 2726 times)
Offline giosifTopic starter
« on: September 20, 2016, 11:35:03 am »
I am trying to understand a board where, occasionally, I see a JFET transistor (specifically, model MMBF4393LT1) with the source and drain pins on the same trace.
What would be the purpose of doing that?
Thanks!
Sent from my D6603 using Tapatalk
Offline Andy Watson
Re: Why short source and drain on a JFET transistor?
« Reply #1 on: September 20, 2016, 11:42:33 am »
The gate junction forms a good, low-leakage diode.
Offline David Hess
  • DavidH
« Reply #2 on: September 20, 2016, 12:13:51 pm »
And at less cost and with greater availability than an actual low leakage diode.
« Reply #3 on: September 20, 2016, 01:53:06 pm »
Ok. Thank you both for the explanation!
Back to "reading" the board now...
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: September 20, 2016, 07:02:20 pm »
Though to be fair, small BJTs (like BFR93) make better diodes -- less series resistance.
Seven Transistor Labs, LLC
Offline danadak
« Reply #5 on: September 20, 2016, 11:52:13 pm »
Depends on the JFET. Some cannot tolerate much I in the gate.
Regards, Dana.
Offline David Hess
  • DavidH
« Reply #6 on: September 21, 2016, 05:08:03 am »
They do but you can buy JFETs with guaranteed maximum gate leakage specifications while transistors just have to meet their maximum cutoff current specifications which are typically tested to 50 or 100 nanoamps.  If you want low leakage from a transistor used as a diode, you have to qualify and test them yourself.
