Author Topic: Shift sensor output voltage up/down  (Read 1342 times)
Offline fskyTopic starter
« on: August 29, 2015, 11:05:30 am »
Hello!
I interfaced a sensor badly on my board and I have to fix it : (
I have an output voltage from a current sensor. It's output swing is as follows:
VCC/2 for no current,
VCC for full current.
How to shift those voltages to an differential ADC input, where I would like to get 0V for no current and 2,048V for full current? I want to discard anything below VCC/2.  VCC = 5V. I can source a couple hundred mA from output (it's op-amp buffered).
Any suggestions for doing it in a simple way and not loosing those important mV above VCC/2?
Is a solution using an op-amp as here on page 25:
http://www.microchip.com/stellent/groups/SiteComm_sg/documents/DeviceDoc/en542976.pdf
a good choice?
« Last Edit: August 29, 2015, 11:08:19 am by fsky »
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Shift sensor output voltage up/down
« Reply #1 on: August 29, 2015, 11:57:02 am »
yes something like that.
