it might leave a blast that kind of cauterizes the surface around it (think of a under ground bomb, it glasses the surface of the rock to make a stable 'cave' bubble) maybe its more stable then you think.
The capacitor might just do that. You might get a thin layers of zinc that is somewhat polished/corrosion resistant from plasma deposition
A plasma drill apparatus makes a self supporting cave because it melts the rock around it. Similar to making a concrete shell inside of a tunnel. This might have a similar but uncontrolled effect. Its not like you just scooped it out, you are talking compaction, plasma deposition and possibly reactions that exhaust the reactive surfaces prone to corrosion and reactions. And the foil might get a kind of "lip" around the spark leading to a geometry that is not conducive to further dendritic growth, and the vaporized plastic might infiltrate the shell to give it a tiny coating, the plastic should condense from the plasma at a later time then the metal, I think its ultimately related to vapor pressure, not sure how matter crystalizes from plasma, I assume its kind of like freezing, where high melting points freeze first.
I am thinking the impulse of a cap might be the ticket to trying to get some of these favorable results.
Perhaps a cosmologist can give insight. If zinc and plastic are both vaporized under the pressure, will the metal condense out first and get coated with plastic?
A practical experiment might be detonating a small nuclear bomb placed deep under solid rock inside of a large zinc container that is surrounded by alot of plastic.
https://en.wikipedia.org/wiki/Plasma_deep_drilling_technology
