Sounds like a plan guys
I might one day break out the bits and pump some audio frequencies in mine with an amp and sig gen starting at 50hz and go from there
fwiw guys: one major design flaw with most if not all variacs IMVHO, and I've seen a few made in the various countries that produce goodies that work beyond 8 hours
is if the carbon brushes snap or wear down to nothing,
the metal housing comes crashing down and destroying the copper windings
The variac may still work at certain ranges due to direct brass or steel to copper contact grinding along
till the operator opens it up to investigate why the unit drops out sometimes, or running warm
Some plastic or isolating material placed just before the 'end of life' point on the carbon brush assembly should stop that from happening,
and alert the operator it's new carbon brush time when the variac starts skipping and arcing/sizzling, or not working at all.
Its a better bet than trashed copper windings which is a pain to fix/maybe,
and I will be rigging up something simple and functional to my humble threesome of variable 240 volt AC units, on the next open and inspect/clean session
Anything is possible with a junk box of 'not ready for landfill yet' scraps, bits and bobs, glue, cable/zip ties, sharp knife, rotary tool
and bottomless cups of tea etc
Have a look next time you're in there guys, you'll know what I mean about it,
it may bite you one day or not,
so why not step in and avoid that, with an easy knockup ugly prevention fix no one will see or care,
rather than forced to replace a decent trashed unit with a clickey clickey online shiny red one,
that's apparently only good for 7 hours and 59 minutes..
