Author Topic: EEVblog #279 – How NOT To Blow Up Your Oscilloscope- QUERY  (Read 371 times)
Offline MS1988Topic starter
« on: January 13, 2025, 01:01:37 am »
Dear Members,
I am beginner and hobbyist. I watched a very educational video below and was not able to figure out at one point how a complete circuit is formed.
https://youtu.be/xaELqAo4kkQ?si=QOlH0zAgsvhZJFHR
In the video above I have a question,  At 12:18 , how a complete current path is formed when we only connect the alligator clip of probe to positive terminal of widget. I can see from positive terminal current goes through alligator clip to earth circuit and back to widget through negative terminal. How the negative terminal is shorted to positive terminal if only the positive is connected through alligator clip of the probe.
New update: After drawing the simplified version of circuit in paper it make sense it's a dead short. Please let me know if my attached circuit and current path is correct when we connect the alligator clip to positive terminal of widget. Please also let me know is what exactly conveyed in the video.
« Last Edit: January 13, 2025, 02:09:25 am by MS1988 »
Offline Grandchuck
Re: EEVblog #279 – How NOT To Blow Up Your Oscilloscope- QUERY
« Reply #1 on: January 13, 2025, 07:53:01 pm »
Yes your arrows trace the short circuit.
The following users thanked this post: MS1988
« Reply #2 on: January 13, 2025, 08:07:09 pm »
Thanks for your reply.
Offline wasedadoc
« Reply #3 on: January 13, 2025, 08:09:05 pm »
Better to term the scope probe lead as such or as a  "cable", not a "wire".  A wire is conventionally thought of as a single conductor. (Even though it may have many strands not insulated from each other.)
