This is because you can run a 3 phase motor on single phase by first spinning it up by hand and then applying power while its spinning.
Well, yeah, that was the phase converter/inverter aka rotary converter I was referring to.
Of course they throw a cap on it so it can start by itself.
We had a machine shop that ran off single phase converted to three phase.
You'd start the converter, then start a shop tool.
You could even turn off the converter at that point.
After that you could even start another shop tool because the first tool is being a converter all by itself.
(Of course the torque is not the same.)
I had an electric lawnmower that the capacitor died.
You'd turn the mower on its side, kick the blade, then switch the power on.
No, this is not recommended by the Safety Institute.
