Author Topic: Should I connect the RF connector ground to the case ?  (Read 72 times)
Offline xani
« on: September 20, 2019, 12:32:14 pm »
So I'm beginning to prepare a case for my LimeSDR, I chose just a simple aluminum extruded one and have few questions about grounding. I assume the case itself should be grounded to the USB ground but for the faceplate with connectors is it better to have something like https://discourse.myriadrf.org/uploads/default/optimized/1X/9bf555e8e6a4a5656ddcec7b58b30bd79ff31d3d_2_300x225.jpg (so just PCB with holes), or just drill holes in metal faceplate and have the connector's ground connected to the chassis ?
