I'm attempting a repair on a WAECO DCDC10 12>24 converter/charger.
My mate brought it around, if I can fix it, it's mine to use.
Could be useful for topping up my field-charge batteries (for RC flying) and our GoGo mobility trike.
It's a pretty solid piece of kit, it does have some quirks though.
The fuses are ATO blade type soldered straight onto the PCB, no holders.
I'll put holders in just in case. Easier than soldering aluminium to copper anyway.
I've improved the way the big coil is fitted to the PCB.
Even though WAECO are German, I think the boards are put together in China.
Fault presented - 40A input and 15A output fuses blown, Schottky output rectifier s/c.
The big choke coil must have got very hot, it nearly fell off the board, the silicone goop held it on, not the solder.
FETs read OK ... well they're not shorted at least.
I'm working blind, no circuits available that I can find and the chips have been helpfully tarred over.
If the control circuits are damaged then I'd be lost pretty quickly. I've no idea what frequency the converter runs at or anything.
Haven't fed it any volts yet but I'm hoping that it's just the diode that died, in fact I'm banking on it.
It's a MBRF20100CT 20A 100V.
There's a place on the board for another one in parallel.
I was wondering if it might be a good idea to use that space and bung another one in there.
It could make it just that little bit tougher.
Can anyone who knows about the workings of this type of power supply think of a reason not to?
Even better if anyone has direct knowledge of WAECO stuff.
I was hoping that a quick trip to my local Maplins would yield a replacement diode but the highest working voltage they have is 60V so I guess I'll have to be patient and wait for mail order on the correct replacement.
