Author Topic: 4 pin PCB right angle fan header  (Read 4041 times)
Offline jshonwTopic starter
« on: June 08, 2014, 09:47:40 pm »
I am looking for PCB right angle headers that can accept 4 pin PC fans.  The key tab is 3 pins wide and is offset to one side, so that it can accept 3 pin fans also.  Do they exist and where can I get them?
Offline fluxcapacitor
Re: 4 pin PCB right angle fan header
« Reply #1 on: June 09, 2014, 12:17:25 am »
do you want thru hole or surface mount. This might do if you notch out the plastic,this one is thru hole.
http://www.ebay.com/itm/10x-KF2510-4P-Connector-Kits-2-54mm-Pin-Header-Terminal-Housing-Right-Angle-/120992682503
« Reply #2 on: June 09, 2014, 12:52:32 am »
Trimming the tab as you suggested on a regular 4 pin might work for now, since I am only at the prototyping stage.  Hopefully, I can find some proper ones, if this project ever goes into production.
Offline peterszilagyi91
  • Country: no
« Reply #3 on: April 16, 2018, 06:06:31 am »
Have you find the right angle version for this connector?
Offline palpurul
  • Country: tr
  • Hey
« Reply #4 on: April 16, 2018, 06:14:47 am »
