EGS002 module datasheet I have the schematic for an APC 500VA UPS. This UPS creates a "stepped approximation of a sinewave". Would it be easy to replace the original MCU with the EGS002? What sorts of problems may I come across?
I can imagine:
- The transformer being a problem due to the significantly faster switching speed of sPWM
- Potentially higher losses in the FET's, due to the faster switching?
- Loss of battery charging functionality? (I'd imagine the UPS would need to become a "double-conversion" UPS, as the EGS002 module only appears to help output 120v, and cannot detect a loss of power on the input?)
Anyone have any input? I'm not sure if there may be an easier way to convert a Squarewave UPS to PureSine? Thanks.
