Author Topic: Siglent 2042X as a test tone generator  (Read 1171 times)
Offline adauphinTopic starter
« on: July 23, 2023, 05:59:44 am »
Could the 2042X be configured in a manner to output a sine wave to be used as a test tone generator into a small speaker at a very low output voltage?
Would need to make this an AC waveform to not damage the voice coil.
This would also be into an 8 ohm load.
Sounds simple enough but wanted to ask before I create any magic smoke... :-BROKE
Offline tautech
Re: Siglent 2042X as a test tone generator
« Reply #1 on: July 23, 2023, 07:55:21 am »
Yep no problem.
Ordinary output is p-p either side (+) of 0V and short circuit protected.
The following users thanked this post: adauphin
« Reply #2 on: July 23, 2023, 09:41:01 pm »
Thank you... :-+
What would be a good voltage? I was initially trying about 30-50mV @500Hz
 but didn't want to take it any higher before I asked here.
Offline tautech
« Reply #3 on: July 23, 2023, 09:57:31 pm »
As the output is a 50 Ohm source an 8 Ohm load will pull levels down so start increasing output until you get the levels you need.
FWIW I'd start at 100mV then increase in 100mV steps.
« Reply #4 on: July 24, 2023, 12:34:27 am »
Should I use a 50 ohm adapter?
Offline tautech
« Reply #5 on: July 24, 2023, 12:45:46 am »
You could which would give you a 25 Ohm source for the speaker but I don't believe it is necessary.
We sold a SDG810 a few years back to a chap that wanted to investigate so called healing frequencies and IIRC we never terminated the output and just drove the speaker directly.
He was an acquaintance and I think I delivered and proved it would do what he needed, which of course it did.
Far too long ago to remember the settings....you'll work it out.  ;)
