I've never bought SDS1052DL into NZ mainly due to their minuscule memory depth for a DSO.
Instead to get the best from a DSO's abilities you are much better off with a min of 1 Mpts memory depth and preferably more.
As this is to be your first scope in that you'll learn to use DSO features and in time you'll come to understand the limitations of a DSO with very little memory.
With all this ^ in mind the least capable Siglents I sell are SDS1102CML and more lately the Plus version that now has the higher res display and a LAN connection.
Good luck with your hunt.
