Without knowing which actual parts you're talking about, it's impossible to see what the differences are. Are they from the same manufacturer? Are they made of the same materials? Is one priced in quantities of 10000?
Quote from: Len on April 07, 2014, 07:24:04 pmWithout knowing which actual parts you're talking about, it's impossible to see what the differences are. Are they from the same manufacturer? Are they made of the same materials? Is one priced in quantities of 10000?Here's the $0.67 one: http://www.digikey.ca/product-detail/en/PREC040SAAN-RC/S1012EC-40-ND/2774814Here's the $2.15 one: http://www.digikey.ca/product-detail/en/4-103741-0/A26509-40-ND/297917Spec-wise I need 0.100" pin pitch, through hole. It will be used with breakout boards, breadboards and perfboard.
One of those is amphenol, one of those isnt. Mystery solved
I've been known to buy extra-long female socket header strips and cut them to length. I cut one pin extra because that pin gets crushed; then I file down the broken ends smooth, and no one's the wiser.What, it's not like the whole damn strip is going to just crumble if you hold your pliers funny near it. Tim
Quote from: ConKbot on April 07, 2014, 08:49:14 pmOne of those is amphenol, one of those isnt. Mystery solved What is amphenol?
Cut them with a box cutter...
Quote from: Rudane on April 08, 2014, 06:13:41 pmCut them with a box cutter...What's that?
We call it "a cutter" here The "box" part has confused me.Thank you for the picture.
