I've recently found myself wanting to solder surface-mount PLCC sockets down by hand, and want/need to improve my technique.
The 'obvious' way to do it is to push out the center part and solder the remainder, but this weakens the socket (also - I can never satisfactorily push it back in place). Instead, I've found myself keeping everything intact and soldering the pins using a very fine-tipped soldering iron and lots of flux - and while this works fine, I inevitably end up burning the plastic in a few places as it's very cramped and I'm apparently not so dextrous.
Is there a better technique for this? I've thought of applying low melt solder paste and using hot air, but I'm not sure if this will scorch the socket? Thanks!
