Hi everyone,
I am hoping that one of you can help me with something that I initially thought would be quite simple... but then found out that it's not... for me.
I have an optocoupler that receives a signal from a sensor and forwards it to a microcontroller.
I would like to connect different sensors with a relatively wide range of signal voltages (3.3V - 24V).
Therefore, the optocoupler should turn on at sensor Voltages above 3.3V. The maximum sensor Voltage is 24V.
The LED in the optocoupler has an absolute maximum forward current rating of 60mA. 2mA is enough to reliably turn it on.
This is the optocoupler:
https://www.vishay.com/docs/84181/tcmt4100.pdfIdeally, I'd like to keep the component count to a minimum and make it work over a temperature range between 20 and 60C.
If you have any ideas, I'd be all ears!
Best regards,
Pete
