Author Topic: Signal Generator Clock Pulse Issue  (Read 1446 times)
Offline JonPyroTopic starter
« on: August 27, 2019, 06:50:06 pm »
Hi All,
I am trying to construct a test rig that will send clock pulses to some boards that have a 4013B flip flop wired as a latch. Rather than directly connect the output of a signal generator to the clock input I thought it would be fun just to add some extra complications and drive the clock pulse from a mosfet instead and drive the gate with my signal generator (Rigol DG822).
This is the circuit:
For my reference I have an LED also on the source so I can visually see the clock pulses get sent, however, an interesting thing happens.
My signal generator is set up sending a PWM of 1hz and duty cycle of 10%:
probed at the mosfet source:
You will notice the first pulse is when I enable my sign gen output, you can see the rise time is much longer than the other pulses, here is the first pulse on its own:
Here is the second and beyond pulse:
This long first pulse is causing the 4013bs to go wobbly as its a invalid clock rise time but why does only the first pulse do this?
I have connected my sig gen directly to my scope input and every pulse is perfect, so it must be my circuit to blame but I am not sure why.
Any help would be appreciated.
« Last Edit: August 27, 2019, 06:52:41 pm by JonPyro »
Offline radiolistener
Re: Signal Generator Clock Pulse Issue
« Reply #1 on: August 27, 2019, 07:56:19 pm »
did you tried to remove LED to avoid output distortions?
The following users thanked this post: JonPyro
« Reply #2 on: August 27, 2019, 08:50:55 pm »
I have tried removing the 4013 boards and the led and it still has a slow rise on the first pulse. Interesting when I remove the led the waveform shows more overshoot and undershoot on the over pulses but the first is still slow.
