Hi Mike Fikes
I got a new signal generator and I noticed that when powering it on it drives the output to -10 V for about a second.
Is this normal? I presume this could damage components you might be testing if you have the generator connected at power up.
I can't answer specifically for your Rigol DG1022Z but, in general, no that is not normal and is unacceptable. And yes, it definitely can damage your unit under test (UUT).
Is it standard practice to power up lab equipment (and power down) without any equipment connected to the circuit you are working on?
Not too sure what you mean here but I will cover all combinations.
Test equipment, apart from possibly specialist types, can be turned on and off with no UUT connected to them or with a UUT connected to them.
In strict theory test equipment should be turned on and then connected to the UUT, but nobody does this.
In a typical set up you may have a UUT connected to three PSUs, a scope, a signal generator and frequency counter say. The monitoring test equipment is not critical. But the PSUs are critical and you would need to check what the UUT requires. There are also situations where a UUT may be stressed if a signal source were connected but the PSUs were not.
The switch on negative output of your Rigol DG1022Z, reminds me of the time at work when we started getting a load of UUT failures, until we discovered that the lab PSUs we were using outputted a 70V spike at turn on.
