Author Topic: Signal Generator - Working Diagram?  (Read 1508 times)
Offline queennikki1972Topic starter
  • We all start out as newbie's..be kind
« on: July 30, 2019, 02:40:38 pm »
Can anyone verify if this is a working diagram?
https://maker.pro/custom/tutorial/how-to-build-a-signal-generator
Siglent SDS 1202X-E - Heathkit IO-4105 - Dr. Meter 0-30v 5a power supply - 862d+ combo unit - Weller WLC100 - Kunkin KL283 DC load. Not much gear yet.
Online ledtester
Re: Signal Generator - Working Diagram?
« Reply #1 on: July 30, 2019, 02:52:16 pm »
Here's a simpler op-amp function generator circuit that you might find helpful:
http://www.learningaboutelectronics.com/Articles/Function-generator-circuit.php
The following users thanked this post: dcbrown73
Online Zero999
  • 0999
« Reply #2 on: July 30, 2019, 05:13:00 pm »
Yes, design will work quite well up to a few kHz.
Yes, that will also work. The big downside is the amplitude of the triangle and sine wave outputs will vary, depending on the frequency setting.
One way to overcome this issue is to use a triangle wave generator and a triangle-to-sine converter circuit. See the thread linked below:
https://www.eevblog.com/forum/beginners/simple-analog-function-generator-design/msg1174983/#msg1174983
