Wooden kitchen counters make the best workbench surface.
The coatings they put on it are very tough while also being nicely textured to give things a constant amount of friction along the surface. They will stand up to quite a bit of heat, you can hit then pretty hard without leaving a ding, can be cleaned easily, stands up to a lot of common solvents... etc
Metal is obviously a bad idea for electronics, you are going to short any board you put down on it. Glass is possible, especially if you just use glass as a cover on top of a wooden table, this makes the glass very impact resistant since the wood below absorbs the hit without bending the glass. But while being incredibly resilient to just about anything, it is not a very comfortable work surface. Laying your forearms on it makes it feel very cold to the touch, will condense your sweat on the surface, making it feel wet and sticky while objects on your workbench slide around all over the place, dropping a screw on glass makes it bounce around like crazy while making a loud noise etc..
My own workbench is a hardwood surface with lacquer on top to seal it, sitting on top of a sturdy thick wooden frame. Nicely stable and solid, the wood surface looks nice, is comfortable to lean your bare arms on, resistant to dings and dents, doesn't scratch easily at all, provides a consistent medium amount of friction, cleans nicely... BUT it has one big flaw... It's not resistant to solvents, like not at all, even pretty pissant ones like ethanol. So get some ContactChemie PCB cleaner on it and the surface becomes as sticky as glue until the solvent evaporates. This is the reason why i recommend a kitchen counter top, it has all of these benefits while also being solvent resistant.
EDIT:
Oh and i might fix this by simply buying an ESD mat. This makes the surface under it not matter so it can be anything you want.
