thank you very much Mark, it helped a whole lot!
i tried 50k, 10k, and 2.2k base resistors. with 2.2k and Rload changed to 100k, THD=0.17%, and the gain is about 13, that's much better. with base resistor being 500ohms, THD=1.1%, and the asymmetrical output waveform is obvious in LTspice, but i get the idea now.
It's partly a factor of the output swing. In many applications, the output is much smaller.
Thank you those who contributed to that point while I was snoozing last night
say in radio RF stages, what's the normal interstage output voltage roughly speaking? just want to have a general idea. why do designer not fully utilize the gain capability of BJT's, is it because of negative feedbacks?
In a radio, the situation is complicated by the interstage coupling transformers - these improve the impedance matching between stages, which reduces losses. They are also tuned to allow only 10.7MHz through, so distortion is less of an issue - these will attenuate 21.4Mhz and 32.1MHz, etc, by a large amount.
Also, don't forget that FM IF amplifiers (at least the last one) are run into saturation to reduce the sensitivity to AM.
At the input to the discriminator coil, it's not uncommon in my experience to see several volts of 10.7MHz.
Rest assured; the designers did all they could to maximise sensitivity, and they generally were very successful. When I restore old transistor radios, I'm always very impressed at the performance achieved from just 5 or 6 BJTs. The challenges were noise and stability (the risk of amplifiers turning into oscillators), not signal level. To understand this, imagine 4 transistor amplifiers connected in series, all with a relatively low gain of 10 to keep the numbers simple, and with an overall output voltage of 5 volts. The input to the last amplifier will be 0.5V. The input to the penultimate amplifier is 50mV. And the input to the antepenultimate amplifier will be 5mV. So as you can see, signal "swing" is only an issue for the very last amplifier in a multistage circuit.
I have not investigated Jay's circuit yet, becasue I know the emitter resistor is going to reduce the gain, then I won't be able to tell whether any THD reduction is due to reduced gain, or circuit configuration, or the BJT itself. I'd like to nail down the BJT first, the gain of a particular circuit configuration the next, and then different circuit configuration the next.
Quite simply, the distortion comes from the exponential transfer characteristic of the BJT, and NFB - however applied - reduces this distortion.
To further lower the distortion, you need more open-loop gain. But this is limited by the gm of the transistor (set by the collector current) and the load resistance. To increase gm, you could double the collector current. But if you've kept the supply voltage the same, this will require a lower value of Rl, so you're back where you started!
Don't forget that the impedance of the following circuit (or 3k9 in your first schematic) is in parallel with Rl, reducing the gain. Everything is against you
To take the performance to the next level, wouldn't it be nice if we had something that passed a current, but had a very high impedance? That, in a nutshell, is why current sources or current mirrors are often used as a collector load for transistor amplifiers. Or, back in the days when BJTs were expensive, we did "bootstrapping" - an extremely elegant technique.
