Author Topic: Pls helpme identify Bridge Rectifier and other component?  (Read 2377 times)
Offline honiTopic starter
« on: September 27, 2017, 04:34:23 pm »
ive opened up a water pump on my prochem industrial carpet cleaner. the bridge rectifier has gone on the pcb and im struggling to find the rectifier from the numbers written on it which are DT816 ADB608.these motors are commonly sold as 12v units so based on that im guessing this motor has 230vacinputthen converts its own 12vdc from the bridge rectifier? its rated at 0.35amps this motor.
also their is another component, silver with numbers 16P-1291 and its a2pin thru hole component.
can anyone help identify this bridge rectifier and where to get one or what i can replace it with if something different?
Offline Monkeh
Re: Pls helpme identify Bridge Rectifier and other component?
« Reply #1 on: September 27, 2017, 04:47:23 pm »
It's not converting to 12VDC - this is a 230V motor.
How sure are you it's the rectifier which has gone?
The following users thanked this post: honi
Offline Andy Watson
« Reply #2 on: September 27, 2017, 04:51:10 pm »
The rectifier is  6A 800V.
http://doc.chipfind.ru/pdf/diotec/adb608.pdf
Can you high light the "silver thing".
Looking at those photos I would say that the brushes are worn out.
Offline Monkeh
« Reply #3 on: September 27, 2017, 04:53:48 pm »
It's the little bimetallic switch. They don't go wrong much.
« Reply #4 on: September 27, 2017, 05:04:06 pm »
yes because I blew the thing by shorting two of the pins like and idiot and a big blueflash and pop GONE. it was originaly just needing new brushes... well if its an ac motor whats the pcd within the motor casr with this bridge rectifier doing?
« Reply #5 on: September 27, 2017, 05:06:49 pm »
thank you for your help, top fella... heres some other pics couldn't include with original post
« Reply #6 on: September 27, 2017, 05:08:50 pm »
what are those weird little black cylinder things with the horizontal drilled holes which have a single piece on continuos wire feeding round and round before coming out and back into the thru hole of the pcb
Offline Monkeh
« Reply #7 on: September 27, 2017, 05:10:29 pm »
It's a ripoff, but this should fit: http://www.ebay.co.uk/itm/KBPC610-DIO-Bridge-rectifier-square-1kV-6A-KBPC610-DIOTEC-SEMICONDUCTOR-/201848601568
It's not 12V - that doesn't mean it's AC. It's probably a universal motor.
Ferrites. The brushes make for a lot of electrical noise, they're there (along with the capacitors) to suppress this.
« Reply #8 on: September 28, 2017, 07:10:13 pm »
can you help me find these two capacitors also. the numbers on each are.
MDC Z321 45 IIL and its the yellow disc through hole capacitor on this board.
440~X1 WYO 2N2 M  250~Y2 their are two of these and their blue disc type through hole capacitors on this board..
ive been struggling to translate the numbers and letters above to identify each.
Offline Monkeh
« Reply #9 on: September 29, 2017, 02:44:23 am »
Those markings are not making any sense to me.
These are 2.2nF X1 and Y2 rated ceramics.
You probably don't need to touch those.
Offline PTR_1275
« Reply #10 on: September 29, 2017, 08:54:07 am »
The bimetallic switch in the back of shurflo pumps is used for thermal protection. All the 12 and 24v ones I've worked on had it.
Online Zero999
  • 0999
« Reply #11 on: September 29, 2017, 12:34:30 pm »
It's not an AC motor. It's a 230VDC permanent magnet motor, with a bridge rectifier to convert the AC mains to DC and a few inductors and capacitors to suppress and radio frequency interference. These are quite common in small mains appliances, which need to run at a constant speed. Dyson vacuum cleaners, use a similar type of motor to drive the carpet brush. A similar type of motor is used in battery operated tools and toys, but with fewer windings, made of thicker copper, given the same power rating
The motor's case should be earthed, unless the whole thing is in a plastic case, with a non-conductive drive system.
Look at the back of the motor, with the brushes removed. You should be able to see two 'U' shaped magnets, fixed to the metal case, at either side of the windings.
« Last Edit: September 29, 2017, 12:36:37 pm by Hero999 »
« Reply #12 on: September 30, 2017, 11:51:00 am »
probably not, but with so few components I figured for the sake of a few pennies I would order all the components just incase as I really need this prochem cleaner back up and running.
