Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Simple current source calculation?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Simple current source calculation? (Read 678 times)
FriedMule
Frequent Contributor
Country:
Can make even the simplest task look imposible.
on:
September 05, 2020, 01:08:57 am »
I have understood that this current source is both ignoring voltage ripples, if voltage is above X and it is not changing much with temperature.
It has 4 resistors and some unknown BJTs.
Can any of you please tell me how to find out what to use / select for a determined value?
Last Edit: September 05, 2020, 01:11:43 am by FriedMule
Logged
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
ledtester
Super Contributor
Country:
Re: Simple current source calculation?
Reply #1 on:
September 05, 2020, 03:11:13 am »
To a first approximation the voltage at the left voltage divider (and also the base of the PNP) will be the same at the voltage at the emitter or the NPN. So the sinking current will be V/R3 where V is the voltage set by the voltage divider.
But the exact values will depend on the transistors used, the stiffness of the voltage divider and R2.
One issue is that the voltage divider itself is connected to the voltage source which presumably will be fluctuating. It should be replaced by a more stable voltage reference.
Last Edit: September 05, 2020, 03:55:42 am by ledtester
Logged
FriedMule
Country:
Reply #2 on:
September 05, 2020, 04:23:44 am »
Thanks for your reply! I like this current source since it, as I understand it, easily can be made to ignore ripples, but I am told it is only usable for a very low current.
I would like a simple current source where I easily can adjust current.
Logged
ledtester
Super Contributor
Country:
Reply #3 on:
September 05, 2020, 04:54:00 am »
I would use a TL431. Check page 30 of the datasheet:
https://www.ti.com/lit/ds/symlink/tl431.pdf
and perhaps this web page:
http://www.bristolwatch.com/ccs/TL431A3.htm
Last Edit: September 05, 2020, 04:55:59 am by ledtester
Logged
FriedMule
Country:
Reply #4 on:
September 05, 2020, 05:14:51 am »
Looks really great, I have looked at page 30 + some more and the link you send. And I love the component!!
But I am not totally sure how to make the best schematic, it looks like it demands a sort of current source and the TL43x is then make it perfect?
Last Edit: September 05, 2020, 05:50:57 am by FriedMule
Logged
ledtester
Super Contributor
Country:
Reply #5 on:
September 05, 2020, 05:35:51 am »
Just follow the schematic on the bristolwatch page... the load goes between "Iout" and GND.
Or watch this video:
https://youtu.be/3DT1Ou9Pgag
Logged
FriedMule
Country:
Reply #6 on:
September 05, 2020, 06:18:18 am »
Thank you a lot, I think I can calculate it now! :-)
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
