Author Topic: Simple go-to constant current/current limit circuit?  (Read 946 times)
Offline Deku TreeTopic starter
« on: August 27, 2019, 10:03:07 pm »
I'm trying to come up with a quick and simple way to limit current to a nichrome burn wire. The wire resistance is about half an ohm. Depending on the wire length it looks like I need around 3-4A. The circuit is powered by a battery of my choice (most likely a small LiPo or Li-ion because that's what I have on hand).
Ideas I've looking in to so far:
The current regulating switches and protection ICs all drop the output voltage when hitting the current threshold. A lot of the other circuits I could find, such as placing a resistor between the output of a 3-terminal linear regulator require a resistor in series with the load.
I'm more or less looking for an "off the shelf" solution, however the current source ICs I could find all stopped about 1A in output. Any guidance would be greatly appreciated.
Offline mikerj
Re: Simple go-to constant current/current limit circuit?
« Reply #1 on: August 27, 2019, 10:14:43 pm »
Because that is the only way you can reduce the current, you can't escape ohms law.  With a heating application like this PWM is a more efficient method of controlling current.
The following users thanked this post: Psi, Deku Tree
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: August 27, 2019, 11:40:16 pm »
Get a switching buck regulator that specifies current mode operation or current-limited output.  Even if it's not an accurate current limit, you should be able to find one that's exactly in your range I think.
Seven Transistor Labs, LLC
The following users thanked this post: Deku Tree
« Reply #3 on: August 27, 2019, 11:54:20 pm »
Makes sense, will do! Thank you both your for help.
Offline HackedFridgeMagnet
« Reply #4 on: August 27, 2019, 11:59:45 pm »
If you can use 2 cells, so between 6-8 volts.
you could use this.
the FET was logic level and you would have to think about power dissipation.
