Since the reactance of the capacitance is much higher than the load resistance (Zener or relay), it limits the current nicely from the high voltage source into the load. A good capacitor will not dissipate power and heat up, while a 10 k resistor would dissipate about 5 W with 200 V across it. That is approximately the reactance of 330 nF at 50 Hz.
