Author Topic: Where to find varactor diodes ?  (Read 2312 times)
Offline lordvader88Topic starter
« on: October 04, 2017, 09:06:18 pm »
Went to make a sweep oscillator then learned of diodes that change their capacitance vs. voltage.
Its possible I have some from stuff I've scrapped ? What old stuff uses them ? I don't want to wait months on ebay.
And is there other ways to achieve the same affect
« Last Edit: October 04, 2017, 09:08:55 pm by lordvader88 »
Offline medical-nerd
  • What's that coming over the hill?
Re: Where to find varactor diodes ?
« Reply #1 on: October 04, 2017, 09:15:18 pm »
Hiya
Have a look at what this chap has done using different types of diodes as varicaps as a start.
http://www.hanssummers.com/varicap.html
Cheers
'better to burn out than fade away'
The following users thanked this post: lordvader88
Offline firewalker
  • Country: gr
« Reply #2 on: October 04, 2017, 09:19:32 pm »
Old analog tv tuners are full of varicap diodes.
Alexander.
« Reply #3 on: October 04, 2017, 09:21:54 pm »
thanks 1st poster, I shall proceed again
I have +3? of those from CRT TVs /VCRs ...hmmm, but in the meantime http://www.hanssummers.com/varicap/varicaporig.html, I'll make it and try common diodes/LEDs
« Last Edit: October 04, 2017, 09:24:40 pm by lordvader88 »
Offline cdev
« Reply #4 on: October 04, 2017, 09:46:30 pm »
I have bought them from vendors who sell parts to people who build stuff.. You can also find a lot of old parts on ebay.
Also, hansummers site will tell you - old LEDs and some other diodes sometimes make decent varactor diodes.
They can save money and space over variable capacitors in receiving applications.
« Reply #5 on: October 04, 2017, 11:24:49 pm »
I have a few old 1980s/90s diodes too
Offline BrianHG
    • LinkedIn
« Reply #6 on: October 05, 2017, 04:00:09 am »
High voltage zener diodes work well, like 75v, 250mw.  Lower voltage zeners have higher capacitance and work well from 0.5v to around 50% below their rated voltage with a smooth curve.  I used to use a few 75v zd with the first 1-12v to make a voltage tuned FM radio & to tune crystals on an MCU port.
Also, look here:
https://www.digikey.ca/products/en/discrete-semiconductor-products/diodes-variable-capacitance-varicaps-varactors/282?k=tuning%20diodes
These below here are expensive, something like 3-9$ per diode...
There are silicon hyper-abrupt tuning diodes from motorola which will go from 300pf down to 10pf in 1 thru 10v.
Only AM radio Tuning diodes have that super wide capacitance sweep VS voltage, wider than Motorola's hyper-abrupt, within the first 10v.  Something like 600pf down to 15pf.  Philips/ECG - Now NXP - used to specialize in these and you find them in PLL tuned AM synthesizer radios.
Offline cdev
« Reply #7 on: October 05, 2017, 05:58:02 am »
Kitsandparts.com or
dans small parts and kits  may have them, otherwise, ebay.
