The relay could do with a back-EMF diode.
What's this got to do with relays? Perhaps you replied to the wrong thread.If an ideal diode circuit is required, then how about a MOSFET plus a couple of BJTs?The stackexchange thread linked below recommends the DMMT5401, which isn't expensive.https://electronics.stackexchange.com/questions/223935/understanding-an-ideal-diode-made-from-a-p-channel-mosfet-and-pnp-transistorsAll that's needed are some zener diodes to protect the MOSFETs' gates.
Quote from: Zero999 on February 19, 2023, 09:39:48 pmWhat's this got to do with relays? Perhaps you replied to the wrong thread.If an ideal diode circuit is required, then how about a MOSFET plus a couple of BJTs?The stackexchange thread linked below recommends the DMMT5401, which isn't expensive.https://electronics.stackexchange.com/questions/223935/understanding-an-ideal-diode-made-from-a-p-channel-mosfet-and-pnp-transistorsAll that's needed are some zener diodes to protect the MOSFETs' gates.Correct me if I'm wrong, but wouldn't this circuit have issues with exceeding the reverse BE breakdown of Q1 when the input voltage is negative? The Q1 BE junction will be reverse biased in series with the forward-biased BE junction of Q2, and once this voltage exceeds some five-six volts you'd be outside of the maximum rating of most common small signal transistors. For the DMMT5401 specifically, max Vbe reverse voltage is 5 V.
Isn't the word simple in the title?
post #6 should've been the final one.(ideal diodes is actually an interesting topic to discuss, but it doesn't really belong here.)
I have a bad experience with a relay as a reverse protection. Relay contacts don't like to work with a DC current, so I guess a Mosfet-based design may work more reliably despite all Mosfet volnerabilities.
Just stumbled upon this LM74610 IC (https://www.ti.com/lit/ds/symlink/lm74610-q1.pdf) and it kind of seems like an amazing and simple reverse polarity protection IC with a somewhat high voltage support of 42v, but I'd love to find one that supports 60v? Anyone used it before (or similar) and recommend it? AFAIK, I don't know it would be possible to add external circuitry to this IC to allow for higher voltage support?
