I have been wandering if this is possible, my idea is to use two high current server power supply's, but use them in place of a linear transformer. I would wire both server power supply's in series for 24 Volts (floating DC negative output, primary earth bonding in tact) Then put that 24 Volts DC as input for a linear regulator with multiple pass transistors high current output at 13.80 Volts. I think it's possible, but not exactly sure how the linear voltage regulator and pass transistors will see the input voltage. In as much as, because it's not linear DC input, would the semiconductors act in a different way, than if it was a linear transformer.
I do have linear transformers, but like the idea of trying, thinking outside the box ideas. I now I could use a buck or boost converter in this configuration, but I'm looking for RF friendly power source.
Thanks for reading, any thoughts appreciated.
