Lithium battery CR2032 = ~225mah. No leaks like Alkaline batteries. 2 of them will cost around 1$.
225000uah/8ua/24/365 = 3.2 years battery life.
CR2450 has a 620mah capacity, though it is something like 3$ each.
620000uah/8ua/24/365 = 8.8 years battery life.
WARNING, get a battery holder. Do not solder wires directly to lithium coin cells.
If you use 4 x AA Duracell or Energizer batteries, they will last this long:
2500000uah/8ua/24/365 = 35 years battery life, fuck yeah!
If you use 4 x AAA Duracell or Energizer batteries, they will last this long:
1200000uah/8ua/24/365 = 17 years battery life.
CR2032 battery holder4x AAA battery holder, 9vbat sizeLOL, all these parts are actually available off the shelf here in Montreal, dirt cheap. Including the 74HC4053.
If you use 4 x D cell Duracell or Energizer batteries, they will last this long:
15000000uah/8ua/24/365 = if they don't leak and somehow everything survives, 214 years battery life.
Note: I know the chemistry will long die out way before 214 years. In fact, knowing Duracell, I bet the batteries will self-disintegrate by year 100.
