Author Topic: SImplest way to get a negative voltage to turn a JFET off?  (Read 2855 times)
Offline K3mHtHTopic starter
« on: February 27, 2024, 03:10:42 am »
Hey everyone, I have a 9V battery powered circuit for a guitar effect.
I'd like to use a JFET to mute something in the audio path, but I'm already using the 9V battery as a positive power supply for the rest of the circuit. My JFET is across my audio path as a "mute" with the Source at audio-ground, which is also power-ground for the +9V supply. So I'm wondering how I can get at least -6.0V at the JFET's gate.
I see that there are charge-pump IC's like LT1054 that can obtain a negative voltage from a positive one.. awesome. But I really don't need any current here, just enough to turn the the JFET off... is there an easier way that maybe I'm missing? Are there 1:1 transformers maybe where the primary can go across my +9V supply and the secondary winding be used in the reverse direction for a negative voltage to the JFET's gate?
Offline MathWizard
Re: SImplest way to get a negative voltage to turn a JFET off?
« Reply #1 on: February 27, 2024, 03:28:31 am »
I think a lot of common JFET's work pretty good with drain and source flipped. But do you have any BJT's ? What's the circuit ? There might be other easy things to tie to GND or there about's, with a BJT, that would mute the output audio.
Offline David Hess
  • DavidH
« Reply #2 on: February 27, 2024, 03:29:14 am »
Biasing the source positive will also turn the JFET off, but you already assigned signal ground and the negative of the battery to ground.
A charge pump can be made with diodes and capacitors if you have a square wave source.
A photovoltaic optoisolator will produce plenty of voltage to bias a JFET off with some current left over:
https://www.digikey.com/en/products/detail/toshiba-semiconductor-and-storage/TLP591B-C-F/2310604
The following users thanked this post: boB
Offline David Hess
  • DavidH
« Reply #3 on: February 27, 2024, 03:31:06 am »
They used to make "chopper" bipolar transistors that could also be used for mute circuits, but a normal bipolar transistor can be used also.
« Reply #4 on: February 27, 2024, 03:40:11 am »
I'm open to using other parts to mute the circuit that might not require a negative voltage, but I need the closed resistance to be 22 ohms or less and the device can't draw much power since this is battery powered.
Offline JXstaystonight
« Reply #5 on: February 27, 2024, 03:44:18 am »
It sounds like you're trying to bias the JFET to achieve a negative voltage at its gate relative to its source. Since you're already using a 9V battery for your positive supply, you'll need to generate a negative voltage to bias the JFET properly.
Using a charge pump IC like the LT1054 is indeed a common approach to generate a negative voltage from a positive one. However, if you're looking for a simpler solution without needing much current, you might consider using a voltage inverter or a voltage divider.
Offline dobsonr741
« Reply #6 on: February 27, 2024, 04:17:11 am »
How about this for muting - cutting the audio path instead of grounding: https://www.premierguitar.com/jfet-switching
No negative supply needed.
« Reply #7 on: February 27, 2024, 04:21:45 am »
Thanks JX, what's a voltage inverter in this case?
« Reply #8 on: February 27, 2024, 04:23:08 am »
I wish dobs! I can't interrupt the audio path (it's too complicated to explain why.. ) Nice article though, thanks for posting!
Offline pqass
« Reply #9 on: February 27, 2024, 04:30:38 am »
555 is cheaper than a LT1054; with just 3 more parts.   Simulation here.
Or substitute any CMOS inverter oscillator.
« Last Edit: February 27, 2024, 04:35:12 am by pqass »
Online magic
« Reply #10 on: February 27, 2024, 06:08:17 am »
ICL7660 is the jellybean voltage inverter, often found in battery powered devices.
Supposedly 80μA supply current with no load.
Note that most JFETs are quite symmetric and the source is simply whichever terminal happens to have lower potential at the time. So your gate voltage must be not only lower than ground, but also lower than the signal when the signal goes negative.
Online Zero999
  • 0999
« Reply #11 on: February 27, 2024, 08:50:46 am »
Why not simply use a small MOSFET instead, such as the good old 2N7000?
Another, very simple way to negative bias a J-FET is to use a photovoltaic output opto-coupler, such as the TLP3905. It also has the advantage of being able to electrically isolate your control circuit.
Online magic
« Reply #12 on: February 27, 2024, 09:30:57 am »
MOSFETs have body diodes so negative signals will be clamped to -0.6V or thereabouts and somewhat soft-clipped even earlier.
A pair of MOSFETs connected in series by the sources may work, but their source voltage will follow negative signal half-cycles and therefore gate voltage must be negative to keep them turned off at all times. So no easier to use than a single JFET.
Online Zero999
  • 0999
« Reply #13 on: February 27, 2024, 09:54:40 am »
It depends on the peak-to-peak voltage of the signal.
I've used a single MOSFET to mute microphone level signals before. Two back-to-back also works, so long as the peak signal voltage isn't high enough to turn it on. If it's more than 1V or so, then yes, you need a negative voltage and you're back to the same issue a J-FET.
Offline oPossum
Online shapirus
  • Country: ua
« Reply #15 on: February 27, 2024, 10:23:39 am »
I may be too paranoid, but this text looks absolutely like ChatGPT-generated to me. Same pattern, same reiteration of the original question, same near-uselessness.
The following users thanked this post: BrianHG, magic
Online Zero999
  • 0999
« Reply #16 on: February 27, 2024, 10:38:28 am »
I've just had a look and there are analogue switches which can deal with negative voltages. They typically don't work up to 9V, so would need a lower voltage, but the current is tiny, so a zener diode will do.
ISL54059
https://www.renesas.com/us/en/document/dst/isl54059-datasheet
https://www.digikey.com/en/products/detail/renesas-electronics-corporation/ISL54059IRTZ/2000555
TS5A22364
https://www.ti.com/lit/ds/symlink/ts5a22364.pdf?ts=1708951514746
https://www.mouser.co.uk/ProductDetail/Texas-Instruments/TS5A22364DGSR?qs=9F2IyUQaA%2FhbjQmUI4VB%2FQ%3D%3D
Offline MrAl
« Reply #17 on: February 27, 2024, 02:37:29 pm »
9 volt batteries are pretty easy to add to a circuit if you have room all you need is a battery connector and a place to stick it.  JFET's also require very little gate current so a 9v battery would last for a long time.  That means if you added a 2nd 9v battery for the negative supply it would last for a long time if you made the circuit draw very little current.  It would most likely outlast the main battery by 10 times or more.
There are lots of ways to generate a negative voltage from a positive voltage, but they will use much more current which would drain the main battery faster.
Online ejeffrey
« Reply #18 on: February 27, 2024, 04:17:28 pm »
A charge pump doesn't need to use much current at all. It also only needs to run when the signal is muted so it shouldn't be a major factor in battery life.
Offline mikerj
« Reply #19 on: February 27, 2024, 04:29:51 pm »
If you go for a charge pump like the ICL7660 be aware that they can be quite electrically noisy, ensure plenty of decoupling, solid grounding and avoid routing any high impedance signals nearby.
Offline Xena E
« Reply #20 on: February 27, 2024, 05:53:28 pm »
Alternative approach.
P ch jfet J175 or similar.
1M from control input to gate, B+ for channel open, take to ground to mute.
« Last Edit: February 28, 2024, 12:41:32 am by Xena E »
Offline BrianHG
« Reply #21 on: February 27, 2024, 07:07:34 pm »
Use the exact same trick we use in some modern high end vacuum tube amps.
Add a 3v lithium coin cell in series with the gate.  (Make sure the Jfet you choose switches completely off at around 2.5v-2.8v, you may need to bin test them, place a small cap in parallel with the lithium cell...)
The coin cell should last at least 10 years.
The following users thanked this post: Muxr
Online ejeffrey
« Reply #22 on: February 27, 2024, 07:34:05 pm »
If you do that, make sure that when unmuted you don't forward bias the gate junction.
Offline MathWizard
« Reply #23 on: February 27, 2024, 07:47:13 pm »
Are modern coin cells really that good that after 10yrs even on the shelf, they are still ok ? IDK how bad they used to be, like in a digital wrist watch, but I'm guessing after 10yrs on the shelf, they would not be much good. IDK maybe they were tho.
Offline BrianHG
« Reply #24 on: February 27, 2024, 10:02:24 pm »
Digital wrist watches used 1.5v cells, not the 3v lithium.  With no load, IE: J-Fet gate current, they will last 10 years unless you are seriously temperature cycling them.  Then expect at least 5 years.
In this possible case, assuming the OP wants the J-Fet as a switch, just add a 10-22 mega-ohm resistor in series to the gate.  Though, make sure the resistor is right up at the gate, touching it without any trace length to prevent any pickup of stray EM signals.  Again, typical vacuum tube amp design precautions.
