Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Simulation of a blinking circuit (falstad)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Simulation of a blinking circuit (falstad) (Read 1084 times)
maelh
Regular Contributor
Country:
on:
January 13, 2021, 08:28:45 am »
Hello,
I have built a circuit from an electronics kit, which works as expected (blinking an LED).
But the
falstad simulation
of it, does not go into blinking mode. It lights up once, switches off, then gets "stuck".
The manual has the circuit (which uses one center-tapped coil of the transformer, but not the other one -- so essentially it just uses two independent coils):
https://www.robotshop.com/media/files/pdf/elenco-pk-101-manual.pdf
(experiment #28, page 43).
I am not sure what I could change to make it work. Any ideas?
Last Edit: January 13, 2021, 08:31:36 am by maelh
Logged
Ian.M
Super Contributor
Re: Simulation of a blinking circuit (falstad)
Reply #1 on:
January 13, 2021, 09:01:21 am »
Two coils do not equal a Transformer, as the simulator doesn't know about the magnetic coupling between them. Try
[this]
version. It errors out after a few cycles but at least it oscillates.
Falstad *sucks* for this compared to a real SPICE simulator running on your PC/Mac. The only thing going for it is its pretty animations! I strongly recommend learning how to use the free
LTspice
SPICE simulator. Its .asc simulation files are commonly used to share circuit ideas here and by other electronics communities.
Last Edit: January 13, 2021, 01:33:18 pm by Ian.M
Logged
maelh
maelh
Regular Contributor
Country:
Reply #2 on:
January 13, 2021, 09:09:04 am »
If you look at the schematic in the PDF, the secondary side of the transformer remains unconnected.
The first simulation does oscillate, too, but it doesn't light the LED anymore.
Last Edit: January 13, 2021, 09:11:59 am by maelh
Logged
Ian.M
Super Contributor
Reply #3 on:
January 13, 2021, 09:21:07 am »
What's the DC resistance of the transformer primary? Falstad *may* be better behaved if you add resistors in series with the transformer windings to match.
However, the operation of a
Blocking oscillator
is largely dependant on the transformer's core saturation characteristics, so Falstad is unlikely to give you realistic results. LTspice doesn't directly support saturating coupled inductors, but you can put a saturating inductor (
Chan model
inductor core) in parallel with one of the coupled inductors to achieve the same effect.
Last Edit: January 13, 2021, 09:32:56 am by Ian.M
Logged
maelh
Regular Contributor
Country:
Reply #4 on:
January 13, 2021, 09:27:20 am »
Thanks, knowing it's a blocking oscillator helps already a lot. I'll read and report back.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
