Author Topic: Single bi-directional TVS = two uni-directional TVSs back to back ?  (Read 2075 times)
Offline BravoVTopic starter
  • +++ ATH1
I need 300V bi-directional TVS, but in hands only have the uni-directional version.
As the forward voltage is insignificant compared to VBR which is at 300Volt, is this doable ?
Max. power dissipation capability in that configuration is also doubled right ?
Offline Zero999
  • 0999
Re: Single bi-directional TVS = two uni-directional TVSs back to back ?
« Reply #1 on: December 27, 2018, 10:06:15 am »
A TVS diode behaves like an ordinary diode when forward biased so yes, connecting two unidirectional ones back-to-back will work.
The maximum power dissipation is only doubled if the over-voltage is AC and has equal positive and negative components.
https://www.mouser.com/pdfdocs/Semtech_Application_Note_TVS_Diode.pdf
The following users thanked this post: hsn93
Online tszaboo
« Reply #2 on: December 27, 2018, 11:30:42 am »
Yes. I've seen people do this all the time. For example one chap was doing it for RS485, he had a 12V and a 7V TVS diode on it. Poor chap had no idea how to design circuits properly.
  • +++ ATH1
« Reply #3 on: December 27, 2018, 05:38:48 pm »
@Zero999 , thank you ! :-+
Yes, its for AC , related to my other thread for building an AC soft starter for inductive load.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: December 27, 2018, 10:50:23 pm »
In fact, the high voltage ones are typically stacks of ~30V parts -- they even build their SPICE models this way, and it gives more energy handling.
Seven Transistor Labs, LLC
  • +++ ATH1
« Reply #5 on: December 28, 2018, 12:58:24 am »
So each of them maxed out only at 30V ?
Offline T3sl4co1l
« Reply #6 on: December 29, 2018, 01:34:36 am »
Each of what?
Each of the dies, it seems that way; but unless you're buying dies, I don't see that's a concern.
  • +++ ATH1
« Reply #7 on: December 29, 2018, 01:50:57 am »
Each of what?
No, not my concern  ;D, you just made me aware of it, thanks.
Briefly at TVS datasheet, and looks like 30V dies stacking is at >= 200V.
  • +++ ATH1
« Reply #9 on: December 29, 2018, 04:23:03 am »
Spec, I am not looking for datasheets, thanks though.
Offline spec
  • MALE
« Reply #10 on: December 29, 2018, 04:41:27 am »
Ah sorry. Misread your OP. :-[
